Topic: BABYFACE headphone output always in mono , Help !
Hi community, I simply don't know what to do anymore, I own an iMac on high Sierra, my babyface and total mix works great but when I wear headphones and use the output on the side of the hardware it only gives me mono signal.
when I open total mix and use the pan all the way to the right for example, I see the main out sending the music to the right however on my headphone I still hear music on both sides.  mono button is not active.
I tried using other headphones, I updated the drivers, I tried restarting, reseting Totalmix, I don't know what else to do, please help me here, I`ll have to sell my babyface if I don't find a solution.
any suggestions from anybody ?
thank you
Re: BABYFACE headphone output always in mono , Help !
Possibly a hardware issue of the TRS plug. You may have to send the unit in.
I am going to try a different trs plug connector later today, if there is a problem on the device how should i proceed ? is there a place i could send it for repair ?
thank you so much, i love my babyface.
v.
Please contact the retailer or local distributor.
If you are in Canada, that would be
Erikson Audio
21000 TransCanada Highway
Baie D'Urfé
Québec, Canada
H9X 4B7
Phone: (514) 457 2555
Fax: (514) 457 0055
E-Mail: info@eriksonaudio.com
Web: www.eriksonaudio.com
Support: Bill.Kinal@eriksonaudio.com
Hi!
I don't think this is hardware issue, because I've got the same problem!!
I'm on latest Mac OS and BabyFace firmware/Totalmix updates
Everything works fine on my Windows computer!
We can not reproduce this. Try to do a Total Reset in TotaMix FX.
Tried total reset, no change. sad
I have Sonarworks headphone version installed, maybe that has to do something with it. But I have already tried it enabled/disabled, uninstalled, reinstalled. All the same result.
I will do a complete OS reinstall soon, will see if that fixes the problem.
Will post the results here
