Topic: Issue with auto sample rate switching
I recently got myself the ADI-2 DAC. However, I'm having an issue with the auto sample rate switching.
I still enjoy watching movies/TV series from optical media. So I use PowerDVD quite a bit. So I used the bit test WAV files with PowerDVD to see if it switches the sample rate.
The sample rate is only switches for 32 bit files, so anything less and it won't change the sample rate but sticks to whatever the windows default is. Also only the 32 bit show bit test passed on the ADI-2 DAC.
What I've already tried doing:
- Update the firmware to the version 30.
- Installed and uninstalled the Madiface USB few times. First to update the firmware. Second to test bit test files as well. Now 16 and 24 bit will show test passed, as long as the correct sample rate is picked out via Madiface. 32 bit will not pass this time.
As I've barely had the device for over a day, so I wouldn't be surprised that I've missed something. Is there anything else I could try to get this to work?
