Topic: Problem in Logic (and only Logic)
Howdy RME folks!
I've spent an unfortunate amount of time troubleshooting an issue between my MK1 Babyface and Logic, and I confess I'm running out of ideas, so I figured I'd give this forum a shot.
I’m a multi-DAW user (Bitwig, Ableton, and Logic), so it’s worth noting that the following issue ONLY happens with Logic. All my other DAWs, as well as Mainstage, are working exactly as I would expect.
Here’s the issue:
If I have the Babyface connected to my iMac, Logic goes into beach ball dance for about 2 minutes after about 2 seconds of normal operations, and this cycle continues until I either force quit Logic or unplug the Babyface.
Here’s what I’ve tried so far, none of which fixed the issue:
Changing audio in/out to bypass the Babyface while it’s plugged in.
Plugging the Babyface into various USB ports
Removing other devices from USB ports
Working with an empty project
Deleting all Logic preferences and rebooting
Reinstalling Logic and rebooting
Rolling back to the 10.4.4 version of Logic
Updating Babyface drivers and firmware (v3.16 and v255)
Using an Aggregate Device interface
Doing a full shutdown cycle
Using Disk Utility to check my drive (everything is ok)
Various prayers and chants
During this time period, all my other DAWs, and Mainstage, have worked perfectly with no slowdowns or any other problems. The issue is isolated to Logic.
So...any suggestions? Thanks for your help in advance! You’re my heroes!
Also, for the record, here's the computer stats:
Computer: iMac (Retina 5K, 27-inch, Late 2014)
Processor: 4 GHz Intel Core i7
Memory: 32 GB 1600 MHz DDR3
Graphics: AMD Radeon R9 M295X 4 GB
OS: OS X Mojave 10.14.5
