Topic: FireFace 800 Bluetooth
Hello to community,
I want to ask the following, I have Edifier Luna e235 speakers which connections are with 3 ways. 1st is Bluetooth 2nd is with optical in and 3rd is with stereo jack. If I want to connect with the optical where should I input the cable in ff800 on ADAT1? I tried it but got no sound out. Also when I connect with the stereo jack I got a mono sound probably cause I need to split in to 2 ff800 out puts (confused) Lasst but not least is there a possibility to transmit sound from ff800 with Bluetooth (with some kind of an adapter connected to one of the ff800 outputs)?
I would appreceiate if you can guide me also on matrix layout
Thank you in advance
