Topic: ADI-2 DAC blocked at 48 kHz?
N00b wrote:elbabouns wrote:Hello. Why not offer an automatic variable sampling frequency on optical and coaxial inputs? Being stuck at 48 khz is frustrating, while USB input works perfectly.
For example, some devices (like the chromecast goggle) can work in 24 bits / 96 khz in optical .
Thank you
ADI2-DACIn SPDIF (optical or coaxial), the RME ADI is not “stuck at 48 kHz”: it will work at the SR you send to it, and it works until 192 kHz.
Many thanks .
HI!
Can not play Hires 24/96 or 24/192 files via optical or coaxial inputs from:
An oppo 203 set in lpcm 24/192,
an oppo 103 set in lpcm 24/192
a chrome cast that can read 24/96.
ADI2-DAC is blocked at 48 khz.
