Topic: Any success with UCX in Class Compliant mode on iPad and amp sim apps?
I have been trying the UCX in Class Compliant several times and I can't get a good result using amp sims such as Amplitube, Bias etc... on iPad Air 2. The UCX is recognised by Total Mix FX, I got the signal from all inputs, but when I use the amp sim application, it does not sound right. I don't have the tone I should have from the app. Especially high gain guitar amps. The apps only allow input 1 and 2 in the setting. It does not support input 3 and 4 for instruments. Maybe the reason why.
I would like to know if anyone had any success using amp sims in class-compliant on iPad? If so, would you mind to tell me your setting?
Thank you in advance for your time.
