bsfreq wrote:Jeff wrote:You can route the dry signal to both outputs on the bottom row, and add effects on the appropriate output channel rather than the input.
Of course in this case all input signals routed to that output will have the same eq and dynamics settings.
Depending on your interface (you didn't mention which RME interface you use) and free I/O, you could also use a physical loopback cable to duplicate the inputs. For example a single adat cable from adat out to adat in for duplicating up to 4 mono signals.
1. Connect a cable from adat output to adat in (or use any other available I/O)
2. Send the dry mono input signal to two different mono adat outputs (submixes)
3. Use the two adat inputs separately, one for your monitor submix, and the other for FOH submix, and add effects to only the input you route to your FOH submix.
1st it appeared to me that in step 2 you simply "waste" more ADAT ports than required compared to my proposed solution using loopback.
Then I remembered that using loopback requires a little bit of processing time.
I do not know/remember, how much additional time loopback processing in TM FX takes and whether the time offset between monitor and FOH would have an impact for your life scenario...
BUT you could modify my proposed loopback solution, so that monitor and FOH both would use loopback and would have by this the same time base without offset. This would still save you the ADAT cable if purchase would take too long:
1- Simply route/double each Mic input to two ADAT OUT ports, ie
Mic 9-12 IN to ADAT 9-12 OUT (monitor)
Mic 9-12 IN to ADAT 13-16 OUT (FOH)
2- Enable loopback on ADAT OUT 9-16
3- Enable effects only for FOH on ports ADAT 13-16 IN
4- Route ADAT 9-12 to monitor HW Output
5- Route ADAT 13-16 to FOH HW Output
Questions to RME, would be very kind if you could answer:
1. Does the solution of using an external ADAT patch cable save some time compared to the use of the internal loopback function of TM FX and how much ?
2. To be able to find the best solution: how much time do these different kind of routings take ?
To route audio from analog HW input
- directly to analog HW output
- to digital HW output - TOSLINK CABLE - digital HW input - analog HW output
- to digital HW output - Loopback - Digital HW input - Analog HW output
3. Assumed bigger interfaces like UFX+ require bigger FPGA. Do those bigger FPGA have also a higher clock rate, so that any time offset introduced by internal loopback function would be smaller because of the higher processing speed ?
Many thanks upfront for giving more insight to be able to find the best solution in terms of "least time offset", etc and whether the bigger interfaces eventually bring even more benefits in terms of maybe less internal processing time for loopback which might also be a selling point like ie more spare ports for loopback processing.
