In TotalMix FX (TM FX):
1. Reset TM FX to have a defined starting point:
- Options -> Reset Mix -> Total Reset
- Options -> Reset Mix -> Set inputs mono / outputs stereo (ADM)
Esp the 2nd step is important I read somewhere, so that ADM works ideally
(mono inputs, stereo outputs).
And I think in the DAW you need to organize it the same.
2. check, that Submix Mode is enabled (on the right side under routing mode)
3. in the control room section (bottom/right) click the "Assign" button
to assign analog outputs to "Main Out", "Phones1" and "Phones2"
I assume, that your speakers are connected to HW Output AN1/2.
- assign: Main Out -> AN1/2
- assign: Phones1 -> AN9/10
- assign: Phones2 -> AN11/12
By this you assign analog outputs to the Control Room Section so that you can use control Room functions like "mono", "mute", "dim", etc ...
Watch TM FX bottom row, as soon as you assign the HW Outputs to the Control room, the channels move into the Control Room to the right.
4. Routing
You can configure a basic routing via Options -> Reset Mix, i.e.
Options -> Reset Mix -> Straight Playback with all to "Main Out"
5. Routing manually configured
Click with the Mouse to a HW output (bottom row in TM FX)
Now you see the routing to this HW output (also called "Submix") by watching
the Fader Positions of HW Inputs (Top Row) and SW Playback Channels (middle Row).
So, if you want to hear the Mic AN 9 on Phones1.
Click to Phones1 (remember, this one is already in the control room)
And now raise the fader of HW Input AN 9 in the top row.
6. Store routing in a Snapshot
Again, routing in TM FX "Submix Mode" is easy like this:
- click to a HW output (bottom row)
- raise faders of HW Inputs and SW Playback Channels
More information on this topic:
- See UFX II Manual, chapter 25 ff
https://archiv.rme-audio.de/download/fface_ufx2_e.pdf
- See my Blog with a step by step primer:
https://www.tonstudio-forum.de/blog/ind … rnal-equi/
- Watch RME Tutorial Videos: https://www.tonstudio-forum.de/blog/ind … al-Videos/
