Topic: No audio from any outputs in TotalMix despite routing correctly - help
A few days ago I accidentally turned off my Fireface 802 from the power switch on the front. When I turned it back on no audio was coming through the outputs in TotalMix - I couldn't hear anything or see any metering in TotalMix. The routing did not change between the Fireface being switched on and off.
I tripled checked all my routings, fiddled with TotalMix's settings, did many Total Resets of the mix, but nothing worked. I gave up and turned off my Fireface. I came back a few hours later, switched it on and everything was working as it should be. I could see audio going into various outputs on TotalMix and I could hear it through my various monitoring systems.
Yesterday it briefly did the same thing: no audio could reach the outputs in TotalMix upon booting up my laptop and Fireface. I restarted the Fireface and it started to work as it should.
Today I've been less lucky. I cannot get any audio to my outputs. It doesn't matter how I route audio or which outputs I select or where I send my Main Out to.... nothing is working.
Today my Fireface has also started to disconnect randomly for a few seconds at a time.
I've tried changing the USB cable and the kettle lead (power cable), but that hasn't made a difference.
I'm completely at a loss as to what to do. I can't find any similar user problems on the forum.
Thanks in advance,
JC
p.s my Fireface 802 is a few months old and was bought new.
p.p.s Just to be absolutely clear: I can see audio metering in Hardware Inputs and Software Playback in TotalMix but nothing in Hardware Outputs
