Topic: Bug?
Hi All
Ive been using totalmix a long time...prob since 2007 on fireface 800...although it has matured so much. I have been away from music for a couple of years but I made it a mission to not get into the continuous upgrade loop. The daw is still xp because I treat it like a hardware box and fixed pallet (picasso did blue for 5 years or so...its not strange :-)
Anyway I upgraded totalmixfx and setup the presets etc. The strange thing is when I select preset 4 (Aurasphere) the fader group drops ganging to output 8. I have them ganged to the master out because output 8 is my sub out and I need DIM etc to stay linked to the master fader level
Could someone try it to make sure its not something whacky im doing? The process is
Load workspace
Select preset 1, you will note it include output fader 1/2, output 8 and main out fader
Select preset 2...still going ok with the same fader group going strong
Select preset 3...fine
Select preset 4 and BANG, output 8 disappears
Confirm by reselecting preset (should I say snapshot) 1
Now you can clearly see that output 8 has been removed from the fader group 1
Not really sure how to simply attach the workspace file but here is a https://drive.google.com/open?id=1sqsia … Kl1vRG7RvZ
