If you are willed to learn how to operate and use Win10, then I see no issues.
I would perform the move piece by piece, use the systems in parallel.
Once its ready do the final cut.
RME ASIO drivers under Windows are superb, no matter which windows version we talk about.
They have, from what I read in forum discussions, even a lower base latency compared to Mac OS X.
You would have advantages and advantages to be able to replace components easier, as you say.
But also when using RME DIGIcheck you have two advantages:
- you can simply monitor every input and output without any "trickeries", no need to work with loopbacks
- you can use Global Record which is not available for Apple, because of Core Audio (non-ASIO design).
If the PC / Laptop is connected to the internet I would advice you to take a good Internet Security Solution.
Solutions that had only low impact in PC performance: Kaspersky, Norton, I am using "KIS" since yeard.
Get a good working disk image based backup solition like "Macrium Reflect Home".
There is nothing better at the moment.
For privacy reasons and to tame some background processes get O&O Win10 Shutup.
Get Win10 Professional, because otherwise you get Windows Updates 1st as Beta Tester.
In Win10 Professional you can delay them, in ie. HOME edition not.
Get a Laptop with Thunderbolt in case you would like to use extension cases in the future or to connect UFX+,
if you see a demand to grow and use MADI.
To enable for fast backups look, that your Laptop has USB 3.2 gen 2 ports supporting UASP
and get an external disk with also USB 3.2 gen 2 and UASP support.
Then you can perform faster backups, especially if you have many small files to transfer and
want to make a 2nd backup, by keeping user data in "native format" (backup by mirroring)
to not get into trouble, shall the disk image SW have issues to read its own archive format.
With Acronis things like this happened in the past, with Macrium I had no issues up to now.
Look that your Laptop supports DRAM upgrades up to the amount that you require, maybe up to 32 GB.
8GB is the absolute minimum to operate Win10. For recording better take 16 GB or more if you require.
Look that you get a device with an ergonomic non-glare screen.
Ensure that the Screens resolution is not to high according to the size of the screen.
If DPI value (dots per inch) becomes too high, then you will get issues to see VSTs in your DAW,
because they usually can not be scaled up ... tiny VST windows are really hard to operate and use.
Tiny knobs, descriptions and uneasy to turn the knobs in a VST, if all is extremely small.
So the best is you get the Laptop, use it as 2nd screen, i.e. for TotalMix FX ... then get an external screen,
and there you place the Application, that you are using.
It still might be the case that Intel CPUs give you better DPC compared to AMD CPUs, to be tested !
Smaller DPCs are better for recording esp under load and when using low ASIO buffer sizes to achieve smaller
RTL between Recording Interface and Laptop.
Read Notebook tests to validate, that the Notebook has no thermal problems.
Bad is, when the CPU heats up under load, so that the CPU frequency needs to be throttled.
This way you do not get a sustained CPU power, the system becomes slower.
Eventually it changes the clock of CPU frequently and clock changes also introduce a certain latency,
until the Cores operate at the other clock speed.
It might be an advantage to get a Laptop which allows for a docking station, as this usually give you more I/O ports for additional Screens, USB etc and its easier for you to take the Laptop without without having to cable/uncable connections.
Avoid USB based docks as they usually introduced issues. Either the old fashiend docks or at least based on Thunderbolt which is in fact external PCIe.
