Topic: TotalMix volume lever not in sync with volume changes made on Babyface
I was under the impression that the volume faders on RME Totalmix are in sync and move with volume changes made on the hardware unit. However, when I make volume changes using the rotary encoder on the Babyface Pro, the volume changes but the fader remains in the same position on the RME software. If I change the fader on the RME software, the volume will jump to the position of the fader. Likewise, if for example my volume on the Babyface Pro was last set to -inf or all the way down using the rotary encoder, if I change the output fader to -9 using Totalmix, if I then try to make further changes using the rotary encoder on the Babyface Pro, the volume will change will occur from the last position it was set on the hardware, not from the current position where the volume's at.
Did anything change? I recently updated to 3.18 USB driver and 1.63 Totalmix. I'm on Mac OSX 10.13.6.
