Topic: Mismatch in device order/labelling between TotalMix and USB settings
I have an issue using multiple devices and the ordering of them. The device order is not the same in "Fireface USB settings" and "TotalMix"
In "Fireface USB settings", I have used 'lexicographical ascending' to set the device order. I have three devices, and they are labeled in the correct order in USB Settings. UFX(1) is our master in terms of clock source, and the channel numbering starts with channel 1 on UFX(1) and goes in order through UFX(2) and finally UCX(3). So the ASIO driver is getting all the channel numbers correct.
However, in TotalMix the labeling is not the same. Strangely, TotalMix is labeling the sound cards differently to the USB settings.
ASIO Channel 1 is on the hardware device labeled as UFX(1) in USB Settings, but labeled as UFX(2) in TotalMix. This device appears second in the list in TotalMix. Our mixer settings, stored as TotalMix Workspace, are being applied to the wrong sound cards – UFX 1 and 2 are swapped. Additionally, UCX(3) as labeled in USB settings, is labeled as UCX(1) in TotalMix, however it is in the correct order as it is third in the list.
USB Settings displays the following tabs in this order: Fireface UCX(3), Fireface UFX(2), Fireface UFX(1)
TotaMix displays the following devices in this order: Fireface UFX(1), Fireface UFX(2), Fireface UCX(1)
I'm using Win10. I have latest driver 1.168 and using TotalMix 1.63 which I found through this forum.
Any help appreciated!
Cheers,
Adam
