Topic: Fireface800 broken FW800 port.
Hello, I?m in big trouble... I have a broken FW800 port in my FF800. What should I do?. The unit has 2 years. I?m in Spain.
Is it a common problem? I didn?t connect it a lot ... like 25 30 times... I begun to have problems loosing sound and suspected because I saw a red light... desconected and saw the port weird.. a little loose ...tried to put it back to it?s proper position and it dissapeared inside... Not very well constructed if you ask me... A little screw holding the port will solve most of these problems, and being a port designed to be connected and disconected on the fly should be a little better. FW400 seems more solid, but I?m in a MacBook Pro and using FW800 drives...
Please, I?m in a hurry.
regards
