Topic: Recommended Optical Switch to use with ADI-2 DAC
I have multiple devices (CD player, network streamer i.e. chromecast audio, TV) that I want to route via the ADI-2 DAC. What are some switchers that are recommended for use?
I have a monoprice 4x1 switch that is capable of 192kHz sampling rate and up to 24-bit resolution:
Product # 13345    Monoprice Toslink S/PDIF 4x1 Switch with Remote
There's an automatic switcher on Tindie that also looks well built:
https://www.tindie.com/products/Beni_Sk … io-switch/
[Mod edit: Mini review in post 5]
Have members here had any experience these two? Is there something else out there that beats these two?
2 (edited by ramses 2020-01-10 08:14:39)
Re: Recommended Optical Switch to use with ADI-2 DAC
Be happy if it works and if it really supports 192 kHz, did you test this already ?
Oehlbach claims that their Optosel 4:1 is capable of switching up to 192 kHz, but they have only TOSLINK's built-in which support only 96 kHz.
Amazon corrected it meanwhile on their product page, with Oehlbach I am not sure. They promised to fix the product and replace my units, but since around 2 years nothing but bad promises and no exchange. So if they have on their product page still 192 kHz, then I fear Oehlbach is still in "dreamland" and is not honest to their customers. Otherwise I would have expected, that they would have processed the service request of my HiFi dealer, to exchange my two units.
Even Oehlbachs service on this issue is far away from being good.
https://www.oehlbach.com/de/detail/index/sArticle/45
vs
https://www.amazon.de/Oehlbach-Optosel- … B00NLA4G8S
Technical background here (sorry only available in german, you need to use a translator: https://www.tonstudio-forum.de/blog/ind … lerangabe/. This translator works nicely: https://www.deepl.com/translator
BR Ramses
3 (edited by willem 2020-01-12 11:55:34)
I have the one on Tindie and it works fine but I have only tried it with 16/44. There is one issue that you should be aware of and that is that the source needs to switch off when not in use. Most of my sources do but my Pro-ject ephono optical preamp with optical output does not. So I put that on a separate input on the DAC (coax with a converter).
RME ADI-2 DAC fs, Quad 606-2 power amp, Quad 2805 speakers, B&W PV1d sub with Antimode 8033 Cinema
I ordered that switch as I could use one myself. Will report how it works as soon as it arrives.
The 'Automatic SPDIF (Optical/RCA) Audio Switch' from Tindie (link in first post) came quicker than expected. I ordered the version with 4 optical / 3 coaxial inputs and 1 optical/coaxial output.
This unit has one single 'issue' for typical RME users: it doesn't speak ADAT, because it uses a special SPDIF transceiver inside.
Apart from that I am really blown away. This small unit does everything right, works perfectly, and passed all my tests without any problem. It works as true pass-through (24 bit audio data and channel status), supports all main sample rates from 32 kHz up to 192 kHz, and selects the inputs automatically as logical (and useful) as possible.
The one thing that astonished me most: the internal chip, a WM8805, offers jitter reduction in the audio band. The Wolfson data sheet does not talk about that at all. Yes, this thing reduces jitter by at least a factor of 40 where it matters, without the use of a SRC. A very rare feature, even more so for such a device.
SPDIF coaxial starts to detect an input signal at 0.3 Vss, but after locking works down to 0.15 Vss, so is very reliable and compatible. The coax output is transformer-coupled and provides 0.6 V (standard is 0.5 V), just the little bit of reserve that one wants to see and needs in real-life operation. The optical I/Os use DLR/DLT2160, the right ones for successful 192 kHz operation.
All I can say is: Highly recommended! Now the only thing missing is another version with remote control...
Update: Here is the jitter suppression measurement. Works even better/stronger than I first wrote. Int Loopback is the AP's Jitter generator loopback to its digital input. At 200 ns jitter (2.5 kHz modulation), the Auto SPDIF Switcher removes the jitter nearly completely. The measured jitter damping is higher than 50 dB.
http://archiv.rme-audio.de/images/autospdifswitch_jitter.png
Glad to hear that it passes the expert test. I am really pleased with its functionality. I don't miss the remote control as everything is automatic.
@MC The only thing missing is RME ADI-2 DAC with multiple inputs of its own kinda like Benchmark DAC3 or upcoming DAC8 Stereo by Okto Research :-) Could have created the absolute game changer if you have decided to do the same...
But anyway, thank you for testing that particular device - been looking at it for a while, because it's the only switcher i know of that works automatically. Good to know there is a proper solution for all of us out there to increase input count of your otherwise splendid DAC.
BTW If you want something remotely controlled, then chinese market is full of cheap devices like that. Can't say anything about theire quality though.
RME ADI-2 DAC FS v2 -> Neumann KH 80 DSP
8
They will fail at 192 kHz or directly after unpacking...
I recently bought this switch. Unfortunately all my 192kHz enabled devices do not work when passing this switch. The RME display flickers an says something like unsupported signal and preemphasis detected. Going back to 96KHz everything is ok. Same devices connected directly to ADI2 work pefectly at 192kHz.
Another glitch is when long cable runs fron Tv are involved, be it optical or coax. Those signal work without hickups when connected directly. When passing through the switch I get drop outs.
Am I doing something wrong?
Since some time Oehlbach offers a Mk II unit for around €88 which supports now 192 kHz.
OEHLBACH Optosel 4:1 MKII
https://www.oehlbach.com/de/audio-equip … l-4-1-mkii
https://www.amazon.de/Oehlbach-XXL-HDMI … S9ANK?th=1
BR Ramses
I'd like to suggest this:
2:1 auto switch https://www.lindy-international.com/2-P … p;pi=70436
Available at Thomann for 58 Eur as well as on Amazon for 60 Eur
Wavelab, Digiface USB, ADI-2 Pro
Only 2 ports and limited to 96 kHz. Then I would spend a few bucks more to get
- 4 ports
- up to 192 kHz
- with a remote
BR Ramses
