Topic: 12mic specs
The preliminary press releases put the SNR >121dB(A) which is impressive. Does the 12mic effectively replace the Micstasy as RME's premium multi-channel preamp?
www.eastwoodrecords.co.uk
RME User Forum → AVB/Dante - Network based devices → 12mic specs
Not at all. These are two very different units, differently attractive to customers and applications.
I understand that the new devices that you announced at NAMM are not TotalMix FX compatible
I don't get your point.
AVB Tool is a recording interface and by this will surely have TM FX support.
Otherwise routing of channels would be impossible, makes no sense, doesn't it ?
M-1610 and ADI-2 Pro FS R BE are AD/DA converter, 12 MIC is a preamp.
Since when do converter and preamps have TM FX support ?
Such external add-on devices get connected to a recording interface by ADAT, MADI, AVB
and then the recording interface performs routing of channels and finally exchanges audio
streams with the PC/DAW and vice versa.
For me everything fits fine into this picture and I do not see where you have an issue.
Whats perhaps new, that Apple has native AVB support which makes it possible to connect
AVB capable HW, so to say Preamps and ADDA converter directly to an Apple device via network.
Similar to Class Compliant devices, that can directly be used by Windows, Linux, MacOS X, iPAD.
Yes, but if you have read AVB Tool specs there's no TM FX support, or at list it's still not on the webpage I have read (https://www.rme-audio.de/avb-tool.html)
S.
ramses wrote:AVB Tool is a recording interface and by this will surely have TM FX support.
Otherwise routing of channels would be impossible, makes no sense, doesn't it ?Yes, but if you have read AVB Tool specs there's no TM FX support, or at list it's still not on the webpage I have read (https://www.rme-audio.de/avb-tool.html)
S.
Ah this you mean .. yes, some of the product icons seem to be missing
- TM FX
- ARC USB
If TM FX would be missing, then no ARC USB support, but I have doubts that this is the intention
sgiacovelli wrote:I understand that the new devices that you announced at NAMM are not TotalMix FX compatible
The AVB tool - as the other two - is a network interface. They are not the typical RME recording interfaces, and thus don't have TotalMix FX. Their routing is a patchbay-style version without mixing capability.
Thanks for clarifying
Will the 12mic be able to act as a USB audio interface, like the Octamic XTC?
The USB port allows remote control and firmware updates without the need to connect it to a network.
This, for example, makes it easy to use it as an extension for a Fireface, using ADAT for audio transport and USB for setup. Audio over USB is not supported.
Best
Marc
