Topic: Babyface Too Quiet?!
Hey, for some reason my Babyface doesnt
Seem to have much output level strength
when connected to my Yamaha Hs7 Active
studio monitors via my computer.
I have my computer playing music
into the babyface which is connected
To my Monitors via XLr Line out. The
Monitors are set to +4dB input sens.
which is half their Total output level,
and the babyface set to its max output
(Amber light clipping).
I am getting Bedroom level volume.
I have to turn the monitors up full
blast (-10dB input Sens.) just to get a
decent level.
I know this is not normal as these are
Very loud monitors and with my instruments
(guitar or keyboard + preamp) I barely ever
need the monitors set more than halfway.
Why am I having to turn my Babyface output
all the way up till it almost clips just to
Get a decent volume? Why is it only putting out
-10dB at maximum output level?
Is there any way to set the output strength
higher WITHOUT going into the red clipping zone?
I can't keep my monitors permanently set to - 10dB
(Full output) because my Axe FX 3 which I use as
A preamp/soundcard to Play and record electric guitars is then Way TOO Loud!! I need to be able to
Balance the babyface with the monitors & Axe Fx
Which is +4dB out
Re: Babyface Too Quiet?!
Which Babyface (old BBF, BBF Pro, new Pro FS) ? The new BBF Pro FS has a switch on the bottom to switch outputlevel between +4 and +19 dBu. But no matter which value you choose it should be loud enough. Just an additional thing to check.
Is DIM activated either on:
- DAW
- BBF
- TotalMix FX ?
Which OS ? If Windows: which driver are you using in your DAW ? PC Driver or RME ASIO driver. If you should not use RME ASIO driver then the Windows sound system (mixer) is in the signal path.
- DAW
- BBF
- TotalMix FX ?
I'm using the old Blue babyface, Windows 10. Not using a DAW for this, I'm using the babyface just to play music. (Windows media player). Have selected Rme analog 3+4 as the sound device. My Babyface is turned up to full output, DIM is NOT activated, and the volume at the computer is 75 % because anything over 75 is too high for the Babyface USB input...
What exactly does that refer to? USB is not an "input"....
I have my laptop connected to babyface via USB, and Babyface outs to monitors via XLR.
I mean the Babyface headroom (input) is almost clipping when the computer volume is set above 75. So when I am playing music on my laptop, I have to lower the volume from 100 to avoid seeing the red zone on total mix fx.
Is the old mk1 blue babyface - 10dB output level only ?
I'm not sure why I can't seem to get the music very loud from the babyface?? My output level is set to max (Amber light), the laptop has volume at 75%, and my monitors are turned up to full. The PAD feature is off.  It sounds good but I don't have as much volume range / potential as I would hope for.
Analog 3+4 is the headphones output. XLR is output 1+2. So if you set this correct, first turn your speakers down a lot. It can be you are still hearing something because in totalmix out3+4 is routed to 1+2 but not at full level.
Hope this is it...
