Sorry if the product disappoints you, but maybe you also have a false expectation that everything must work in a few minutes. TotalMix FX is optimized for the application, but this requires a certain kind of operation. It is not difficult, you only need to understand the concept.
It's really only a small thing, but if you're very impatient, it can have a big impact.
If I were you, I would concentrate on the ease of use in submix mode.
Submix Mode in brief:
Every hardware output is also called a submix. So if you want to create a submix / routing for an output (like i.e. monitors or phones), you don't have to do more than:
1. click on the HW output (bottom row)
2. then pull up the faders in the upper and middle rows to create the desired submix for the selected output.
The faders in the top row refer to the inputs of your recording interface.
The faders in the middle row refer to what is coming from the computer (OS, application, DAW).
If you send something to an RME output from your computers application, then it will appear in TM FX in the "middle row" ("Software Playback channels"). From there the output signal can be distributed further to different HW Outputs (aka submixes - bottom row in TM FX) as you like.
And this makes sense, because
- the signal might need to be routed to i.e. 2 headphones or even some more channels
- some application maybe only support one output channel.
TotalMix FX SW Playback channels acts as a kind of "intermediary", where you can easily set the final routing and save it digitally in snapshots with the aim to recall it quickly at any time. You see the 8 Snapshot slots in the right side ?!
Non-ASIO aware OS / Applications -> WDM devices
Windows and Applications who do not support ASIO need the WDM devices.
You create those in the RME driver settings, best only for those i/o ports which you require (speakers, phones, mic).
There is a TAB speaker, selec the I/O port which you want to use as default windows sound device.
Such an entry is created in the Windows audio settings.
There you need to make is the default sound device. Thats it for sound output under Windows and non-ASIO aware apps.
Please have a look at the RME tutorial videos to get an overview of the possibilities. The videos are very short and to the point, so you won't waste any time. I put together here, which Tutorials are available: https://www.tonstudio-forum.de/blog/ind … l-Videos/. Links to the latest videos can also be found on the webserver.
After that I recommend my step by step guide for a TM FX initial setup: https://www.tonstudio-forum.de/blog/ind … rnal-equi/
Then maybe you should also learn to read a manual selectively.
The first chapters are of a more general nature, after that you can set priorities and then you will find helpful information. But you also have to learn how to use a manual. Just give it more time and then you will realize that you may have judged a bit hastily.
Otherwise, just ask in the forum as usual, there are many users here who can help other customers with their problems. But then please turn off the "wind machine", thank you very much, then the "user helps user" support makes more fun.
