Hi, Vincent, Thanks for the reply.
(I corrected a mistake in my first post, it’s not ‘in the first jack output of the AIO’ but ‘in the first jack output of the AEB8-0’, of course.)
I didn’t find the doc on the RME site (bad signal…) but here : https://www.manualslib.com/manual/45979 … ortunateli
Unfortunately, it seems you’re right Vincent :
Quote :
4. Technical Specifications
Output AEB4-O: 4 x 1/4" TRS jack, servo balanced
Output AEB8-I: 4 x 1/4" TRS jack, unbalanced
Dynamic ratio: 103 dB (RMS unweighted), 106 dBA
THD+N: -95 dB (0.0017 %)
Frequency response -0.1 dB: 10 Hz - 21 kHz
Output level for 0 dBFS @ +4 dBu: +12 dBu
Output level for 0 dBFS @ -10 dBV: +2 dBV
Crosstalk: > 110 dB
Supported sample rates: 44.1 kHz, 48 kHz
Output impedance: 75 Ohm
Power supply uses 3.5" floppy connector, 12 V/5 V DC, 190 mA
Standard bracket, board dimensions AEB4: 85 x 95 mm, AEB8: 120 x 95 mm
End of quote.
So I’m trapped. No solution to work in 96kHz with this…
Great disappointment…
Note : I have no Smux option in the card setings.
Gabriel Plalame
