Topic: Fireface UC Constant Tone around 16kHz
Hi RME community,
apologies if this is a common question, I have done a couple of google searches with no luck and figured it might be a good idea to ask here.
I am experiencing a problem with my Fireface UCs inputs.
While recording my Guitar on inputs 1-4, a constant tone makes it into the recordings around 16kHz, if I record silence with no input plugged in, no tone is being recorded.
I have tested the same with my synth and the tone does not appear to be recorded on Inputs 1 and 2, but is existent on 3 and 4.
I am using my Fireface with the EUR Power supply, but in a UK power bank with a power adapter. I am currently waiting on a Myvolt UK Power supply which Myvolt claims to work with the Fireface, to see if the power conversion is the problem/causing interference.
I have tried a different EUR RME power supply, which did not change the error, tried a different USB cord and also tried it on two different PCs. Different 1/4inch cables were used as well, but I might get a Stagg balanced one just to make sure.
I have attached a couple of Spectograms and my input settings, hope this helps!
Thanks and all the best
