Topic: Noise and distorsion issues with HDSP 9632 + AO4S-192
I am long time user of RME products and I have been using AEB4-I and AEB4-O with my HDSP 9632 without any noise or distortions for years.
I bought AI4S-192 and AO4S-192 to replace my AEB extensions and now I have very loud noise and when I play something its heavily distorted. I have two HDSP 9632 and I tried it on both cards and its the same problem, identical noise and distortion so I can say the problem is with AO4S-192 card?
Do I need to change anything in HDSP settings?
Currently I'm back on my AEB until I fix this, if its even possible?
I'm using Windows 10 64Bit, with latest firmware (155) and latest drivers (4.30)
RME HDSPe AIO| RME Fireface 400 | RME HDSP 9632 | RME WCM | AEB4-O | AEB4-I | AO4S-192 | AI4S-192
Re: Noise and distorsion issues with HDSP 9632 + AO4S-192
What are the outputs connected to? Does the "distortion" happen regardless of signal level?
3 (edited by Dinko 2020-05-07 15:40:20)
I tried all outputs from AO4S-192, same problem, heavy distortion when playing music (any level), weird EMI like beeps and noise when idle.
That sounds like a voltage might be missing - is the HDSP9632 working correctly on its analog I/Os? Otherwise I have no idea.
Hmm, voltage could be the problem, I'm using Delock PCIe to PCI riser since I don't have PCI slot and it has power connector that goes to the PSU, it works fine with AEB because AEB is connected separately to the PSU and AO4S-192 is connect to the card directly without additional power like AEB. I tried on another PC with PCI slot and it works, do you think its Delock riser/adapter related and I can't do anything about it?
Make sure the power is properly connected to the delock. Or try another connector from the PSU.
HDSP9652+ADI-8AE  2X HDSP9632
Cubase pro10
Thanks, will try today with another PSU slot
Tried different cable and different PSU slot, same thing. But I notice only 2 LED's light up on AO4S when connected to Delock, so its definitely not enough voltage ?
Or a missing one, might be a delock issue or fault, ask them!
IFAICS PCIe only suplies 3.3 and 12V. The 5V is comming from the adapter. I don`t know which the RME daughterboard is missing.
Maybe also try a different PCIe slot, maybe a 4x or 16x too.
Cubase pro10
10 (edited by Dinko 2020-05-08 16:55:39)
Problem is I have Maximus Gene XI motherboard and only have one PCIe x1 slot, other one is x16 and its used by the GPU.
This is the one i used, nothing specified about voltages:
https://www.delock.com/produkte/S_41857/merkmale.html
Here it mentions 5V:
https://www.reichelt.com/at/de/de/en/ri … 9.html?r=1
RME Manual:
Note: the AO carries three SMD LEDs, indicating the presence of the power supplies +5V, +12V
and –12 V.
11
...and -12V is now missing. I asked you above: it would mean that the card's own analog I/Os also fail.
You are right, Analog I/O has the same issue as AO4S, only AEB works, so it's definitely Delock problem. Only solution is probably to get AIO or another motherboard I guess?
13
The PCI Express bus does not provide -12 V anymore (also +5V are missing). Our HDSPe AIO card therefore generates -12 V out of the still existing +12 V.
This is not a known issue. Could just be a defective delock. Or a bad delock ribbon cable connection.
Startech are known to work ifaik
Cubase pro10
15 (edited by Dinko 2020-05-09 17:46:09)
Thanks guys for all the help, I will probably get RME AIO at the end to solve this. It will be better in the long run.
Installed RME AIO today, together with A04S-192, AI4S-192 and WCM, everything works perfectly, no noise, all leds on all cards are green cool
Hi excuse me, I read your post about AO4S and AI4S expansion cards. I installed the AO4S on the HDSPe AIO, it works very well but I can only get the 3 and 4 outputs, the 1 and 2 don't go out at all. It should be just an enabling problem but through HDSPMixer (I use Linux), I was able to enable only 3 and 4, 1 and 2 I can't get them out. I tried in the mixer drop-down menus to select the analog outputs but nothing I can't do. Do you happen to have any news you can give me? Even using Windows, I think the mixer is the same or I know it's the same in functions...
Make sure that when you select HARDWARE OUTPUTS 3/4 and 5/6 you have SOFTWARE PLAYBACK 1/2 channels up to 0dB
I'm sorry, but I don't think I understand what you're trying to tell me. How do I see this software enable in the mixer, where should I look at this option you tell me? I don't know it...
