Topic: UFX+ with SSL Alpha-Link MADI AX 24
Noob question here. I've got a good deal on an SSL Alpha-Link MADI AX 24. I have an RME UFX+ and my plan is as follows...
Because my PC does not currently support Thunderbolt I would like to pair the UFX+ with the SSL via ADAT. I'm hoping that I can then route the 16 analogue ins/outs via ADAT to and from the UFX+. I'd then like to connect the analogue ins/outs of the SSL to a patchbay using D-sub => TRS cables. Does this sound like it should work?
Lastly, If this is a feasible configuration, I'm not sure about clocking. Do I need the UFX+ to be the master and SSL the slave? Do I need to connect them using the BNC connections to transmit wordclock?
Would be grateful for any advice on this approach.
Tnx
