Topic: [Solved] Digiface USB-Panasonic WRDA7-Input in TM but not in DAW
Dear RME professionals and users,
since a few days I am focussing on my 16ch Recording Setup based on a Panasonic Ramsa WRDA7,
the Digiface USB and Ableton (Cubase).
I have a mac 10.15.5, installed all actual RME drivers incl. FUT, set up the In/Out in updated 10.1.14 Ableton after choosing the Digiface as my interface. I connected the digiface with the WRDA7 via ADAT 1 and 2 via 4 Toslinks to get the 16 ch In/Out.
My 16 instruments are seen in the WRDA7 Mixers channels and even it arrives to Total Mix FX to ADAT channels 1-16.
In TMFX I routed it to the Main (Adat 1/2) and the PH. Up to here everything works like expected.
I then set up 16 Audio channels in Ableton like Ext 1, Ext 2 to Ext 16.
The Problem is that there seem to be no signalconnection from the Hardware Inputs to Ableton.
And the Paradox is that when I am firing a midiloop from Abletons Drums and set it to i.e. Ext Out 1/2
it is seen in the Software Playback in TMFX and I can even listen to it via channels 17-32.
I now ordered a new Digiface from Thomann because this is a very desperate situation.
Since it feels like I tried out every possible mistake. I installed even Cubase but same situation here.
I see the Inputs arriving in TMFX but not in the DAW while I can
I could send all images from the process and hope we will find a setup mistake I made.
My last idea was to check the Matrix view in depth because I am not sure if there is everything set correctly.
Much Love
Sebastian
