Topic: UFX+ Orion32 record latency issues
I am using a UFX+ with an Orion32 via MADI connection into Cubase 10.5
I noticed that Cubase is recording signals directly from the UFX+ ahead of time.
I am using a printed metronome track to measure latency
via headphones out direct into the RME pres measures @ +11 samples.
recorded directly from speakers out with a microphone into cubase at @ +7 samples
If I was only use the RME this is not a major issue as I can easily offset the recording inside of cubase to shift the recording back in time so it records properly.
the problem comes into place when using both the RME and Orion tracking multi mic sources such as drums.
The Orion32 via headphones out direct measures @ -23 samples.
recorded directly from the speakers with a mic measures at -20 samples.
I understand that each unit has a native round-trip latency as all units have different measurements.
As of now. If i offset Cubase to record the UFX+ to record at the correct time I have to use a setting of -7 samples.
In doing so all my hardware Preamps connected to my Orion32 are recording @ -27 samples.
Does anyone have any advice or creative ways I can fix these units in order to makes that record and print at the correct time?
any advice of thoughts would be greatly appreciated.
B.A
