Topic: Audirvana - RME ADI 2 failing RME wav bit test
Hi there,
I completed a bit perfect test with my RME ADI 2 DAC, utilising the RME bit perfect Wav files.
Using Audirvana, the tests pass on 16, and 32 bit depths, but fail on the 24bit wavs, passing through at 16bit.
As a comparison, I used Jriver and Foobar, to perform the same tests.
Jriver passed on all bit depths. 16, 24, 32bit, no issues.
Foobar passed up to 24bit, but failed on 32bit depth.
I am not using any sampling, or volume control.
All tests used the same Asio driver from RME.
Here is a thread I created at Audirvana. I was wondering if anyone could help explain why Audirvana fails the 24bit test?
https://community.audirvana.com/t/rme-a … ails/17298
Thanks heaps.
