Topic: Fireface 800 - firmware update hangs
I have pulled my FF out of storage to connect to my new system and was advised the driver required a firmware update to 2.77 (it was 2.47 or something before).
So, I downloaded the firmware and ran it. It started the update process andthen hanged once the progress bar got to the end with the status still saying 'programming..' I waited for half an hour then thought I would try rebood the FF. When I did, it is now booting up 1.8 - which I assume is from the secondary BIOS.
So now I have a FF that will not update its BIOS, and is therefore unusable. Seems the BIOS deletes just fine, and then the update proceeds - it just fails at the last hurdle..
Where to from here?
