Topic: HDSPe AIO | TotalMix level visible but no sound
Hello!
I recently upgraded my system (Mainboard, CPU, RAM) and with that also replaced my HDSP 9632 with an (used) HDSPe AIO.
Now I'm stuck with a no sound problem both in Windows and Reaper (ASIO).
Analogue 1+2 is set as (the only) WDM device and it's also set in the Windows 10 Sound settings as standard output device.
Whatever i set as my WDM device, I can see the meters working in TotalMix, there's no mute switch activated, but no sound is coming out of my BOB1 or AO4S-192 AIO - which is being detected fine and showing A3+4 and A5+6.
I set up my system from scratch which didn't fix anything.
I tried downgrading from 4.30 to 4.29, also did nothing.
I checked the connected breakout cables and the ribbon cable of the AO4S, all connected fine and without the ribbon cable connected, there's still no sound.
I deactivated the OnBoard Audio device, didn't fix the problem either.
MIDI Input through the BOB1 is working. Can't test SPDIF.
My ADAT Input coming from a Focusrite Interface works fine too. During testing the Interface was usually turned off.
I didn't test the card in another PC yet, nor did I test breakout cables.
I hope it's just some tiny little setting I didn't find yet, that's causing me all that trouble.
Any ideas?
Thanks in advance!
