Topic: UFX II stand-alone mode: how to change mix settings?
Dear forum,
I'm new to the UFX II – and I just can't figure out how to change mix settings at the unit in stand-alone operation.
Following the manual (p. 48):
– I press the CHAN/MIX button twice to get to the Mix menu.
– Then the manual says: "The Mix to menu gives access to the whole submix functionality. Encoder 1 selects the mix destination, encoder 2 the source." That works, I can choose mix destination with encoder 1 and the source with encoder 2.
– BUT NOW. Manual: "A source can be modified in mix level and panorama." Here I'm stuck. I can click encoder 2 to select mix or pan fader of the current source, but then turning the encoder doesn't do anything.
Any ideas what I'm doing wrong here? Thanks!
