> should I install the updates as they are released?
What answer do you expect ? Of course ! They contain updates and bugfixes, see manual.
> Why is there a driver update and a flash update?
I explained it to you already in my last post and you can re-read it in the manual ch6.
Firmware is for the device itself, the driver is for Windows.
Both are executeable files ".exe", but the
- driver update installs the driver (ASIO and WDM) and makes the device accessible for Windows and installs TotalMix FX.
- flash update updates the device through USB with the new firmware.
> I am assuming they will still be there after updating but would appreciate a confirmation.
Of course or do you think a driver / flash update erases your disk ? Those config files are config files of the application TotalMix FX, and if you do not wipe it from disk it will be still there for a restore operation.
