I am also using a MADI PCI and an AES32 PCI card but plugged directly into my motherboard. My master bus DAC is interfaced with the AES32, my multi-track record channels feed Nuendo via the Madi card. I need the AES 32 to show up as Card #1 in order to conviently choose my outputs in Wavelab and as mix channels in Nuendo. No matter how I reorder the cards in the PCI slots, the MADI always shows up as Card 1 in the card order. Is there some code available somewhere as a patch that will allow the user to change this situation?
I have previously addressed this issue and received numerous work arounds, non of them were acceptable since I also have to other systems in use with slightly different i/o configureations, causing numerous logistical, time consumming problems when moving projects. The best solution for me is to make my AES32 card #1 and my MADI card #2. Is there anyway to acheive this?
Thank you
Jim Fox
previous disscussions
http://www.rme-audio.de/forum/viewtopic.php?id=1462
http://www.rme-audio.de/forum/viewtopic.php?id=1467
Win7x64.Nuendo.Samplitude.AES32 PCIe.MADI PCI.ADI 648.Apogee Big Ben.DM2000.Apogee 16XAD.RME ADI 8s
