Topic: Most Latency-Efficient Way to use 3 FF800s on a Mac
If I want to use 3 FF800s at once in my DAW software on Mac OSX, are my only two options:
1. Use an OSX aggregate device to gang the 3 FF800s together, and suffer the major latency hit (64 samples to 256 samples), or
2. Get a Digiface USB or similar, use it as the audio interface, and use the FF800s as A/D converters via ADAT into it
Any other options?
Context, and more info:
So I have been a long-time user of a FF800 (since around 2005 maybe) and am perfectly happy with it.
I recently purchased a couple more after reading that chaining them enables the operating system to "see" them as a single interface. I was really disappointed to discover this is only a feature on Windows, and that in Mac OSX you still need to create an aggregate audio device to use multiple FF800s in your DAW software at once, just like any other set of multiple audio interfaces. Bummer.
When I add all 3 to an aggregate device, my latency takes a major hit. Like, what was a rock solid 64 sample buffer size in Ableton Live now requires 256 for the very occasional stutter, which is not really useable.
So naturally, I'm eyeing the Digiface USB as the interface (I'd like to keep everything RME since I've had excellent driver experience with them ever since using a Hammerfall PCI card in the late 90s/early 2000s) and running the FF800s as A/D converters.
But i was hoping to have a 16 channel round-trip connection to a sampling computer via ADAT x2 and so I really ideally would need to have 5x ADAT I/O....bummer again since RME don't sell a version of the Digiface USB with more than 4 ADAT I/O. So, next option I've considered:
Maybe the solution is a network audio approach (maybe AVB or maybe Dante) but I'm still deep diving into researching these topics to see how it would or wouldn't be possible to use 3 FF800s on a network audio setup, and then use network audio to connect the sampling computer instead of ADAT. I see that MOTU makes a device (LP32) for under $1000 that includes 4x ADAT I/O and also has AVB, but I LOATHE the idea of going back to a motu interface after being spoiled on RME drivers for the last 20 years. It would be an immediate buy for me if RME made something like the LP32.
Am I missing anything?
Thank you all!
