Topic: Madiface XT - ASIO drivers not picking up mic input
Hi!
I'm new to this forum so I hope I posted this in the right section, please redirect me if I messed up.
I'm also new to the whole RME ecosystem and have recently picked up a used Madiface XT. It works just as expected except for the ASIO driver. In my DAW (Reason) I can select two inputs apart from all the MADI inputs:
- MADIface USB Analog 1
- MADIface USB Analog 2
As far as I can tell these should be the mic inputs on the interface itself. However, I do not receive any signal. I have the same issue in iZotope's RX 8, however here is where it gets complicated.
I can select the MME driver which works in RX 8 but with the same driver does not show any audio inputs in Reason which is weird. ASIO4ALL works but the latency is not great with a minimum of 10ms along with the other drawbacks.
To be clear: The mic inputs do work and other software that uses the mic inputs (like Zoom, Discord, Skype, Teams etc.) does work just fine.
Is there some setting I need to change so I can get audio into Reason using ASIO?
Thanks in advance for any help! Cheers!
