Lerian wrote:waedi wrote:I was surprised from reading of DirectX, I remember this from Win98, thought it is not in use since then.
Wondering if there is some more to choose beside Asio and DirectX ?
Maybe Asio4all ?
DirectX will always be part of windows, is the driver that allows apps to use hardware resources in a more direct way.
No, Asio4All would behave exactly like RME Asio. The problem i think is in TMFX.
Can anyone else replicate my problem? Thanks.
Lets leave out ASIO4ALL, this has nothing to do with it and no ASIO4ALL is not smth like an ASIO driver, its a cheap solution to create workarounds based on bad planning (e.g. to integrate USB Mics and alike), but is a not supported solution.
You didn't detail your setup enough to be able to replicate it and didn't even answer lightbox's post #2 "What software do you use to record the screen capture?"
I think the following would be helpful:
- name and version of the software that you are using
- screenshot of the audio settings and maybe also of TM FX routing
- something like a drawing or better explanation what you want to achieve exactly
Maybe its only me, but I have problems to understand what you want to achieve exactly and what routing you configured up to now.
@MetalHeadKeys: thanks, yes could go into that direction..
