Re: New RME AIO Pro terrible Cubase Performance
Just a FYI, and everybody reading. Motu is pretty good. If there would have been any improvement it would have been in the lower buffer range, like 32 to maybe 128 or 256 samples. Al drivers except the very bad perform good and the same at 1024.
The only things I can think of is that it is either a pcie mobo issue or the driver needs improvement. Or the card and the network are interfering. Are you sure you did not change something in your network? I had samish VEP problems when I put one computer through a different switch by accident. If you still have the motu, try and see if that still works. Might be coincidence, that it happened when changing to rme. Don't worry about having multiple drivers!
