Topic: [Solved] AIO Pro vs AIO - BUFFERS
This question has been prompted by an observation made by another user in topic
https://forum.rme-audio.de/viewtopic.php?id=32694
He stated there that "It seems that AIO Pro is not that well optimized as the AIO, as one user has stated, and there must be something off with my setup too"
While this thought was debunked by RME Support, I have noticed something strange happening with the AIO Pro card that I never observed with the 'old' AIO card. I actually have both cards installed in the same PC, everything working great with both cards apart from the following issue.
OK, let me get the groans out of the way first, I am running Logic Audio Platinum 5.5.1 under Windows 10 Pro (please don't ask), all latest patches, firmware, drivers etc.
With the AIO Pro I get two issues - one if the buffer size (DSP settings) is too small, another if it gets too large. Trouble is, finding the optimal buffer size between the two is almost impossible, as I will now explain. As I said, I never had these issues with the old AIO.
With a buffer size of 512 or even 1024, after a few recording 'takes' the dreaded audio 'crackling' begins to appear (most will immediately know what I'm talking about).
And of course with a buffer size of 2048, when played back the recorded tracks are out of sync with tracks already recorded.
I should mention that the ASIO buffer settings within Logic Audio cause similar behaviour (although the settings there are fairly coarse, being just small, medium and large). 'Small' tends to be too small, 'Medium' can be either too large or too small depending on the occasion and 'Large' tends to be too large !
Can anyone please shed any light on this? I think I'm missing something! I have a workaround by relaunching Logic Audio far too often (either directly or by changing the DSP buffer size) but that is a real pain during a recording session. And WHY did I never have this issue with the old AIO card? But don't ask me to go back - the AIO Pro is fantastic ...
