Topic: WDM settings confusion with Fireface UFX
The version of Fireface USB Settings I use contains a 'WDM Devices' dropdown list that is not present in my User Guide so I'm a bit confused as to how to set it.
I'm using a Fireface UFX with two Steinberg MR816csx interfaces attached to the UFX via Adat.
In the WDM dropdown list I can select from 0 to 15, but What number should I select?
Should I just set it to '15' and forget about it, or could that cause problems?
I've not noticed a problem before, but I'm currently experiencing occasional loss of input signal when recording through the MR816's into the UFX and wonder if the WDM setting could be causing this.
