FD10 wrote:Hello RME Team
Hi FD10,
nice to meet you. I am not from RME, but I can give you some good ideas for building a very nice environment.
What do you need the environment for, what would you like to connect ?
How high is the budget that you have set for yourself?
What surprises me in your listing of the devices is that you:
compare devices with and without TotalMix FX with each other, as if it does not matter so much and
in terms of the ADI-2 FS you even list a device which is a pure converter, even without USB audio interface.
The routing possibilities that TotalMix FX offers can also be used in situations that have nothing to do with recording. For example, to create a well balanced submix from several different audio sources, such as the following, which I once needed one evening, to achieve the following:
1. play a game
2. listen to my own background music
3. listen to a Youtube tutorial of the game in the background
There are also other ways to combine RME devices. A recording interface with TotalMix FX as base and then either ADI-2 DAC FS or ADI-2 Pro FS R BE via ADAT. I described such a setup here in my blog article:
The advantage is, that you could use the very unique and useful features of ADI-2 DAC/Pro for monitors and phones
and to create monitor mixes with high flexibility that TotalMix FX offers.
To put some examples that might fit, depending on your MACs capabilities and other demands:
- Digiface USB (USB) and ADI-2 DAC FS = €357 + €966 = €1323
- Babyface Pro FS (USB) and ADI-2 DAC FS = €698 + €966 = €1664
- RayDAT (PCIe) and ADI-2 DAC FS = €585 + €966 = €1551
or the same using ADI-2 Pro FS R BE
- Digiface USB (USB) and ADI-2 Pro FS R BE = €357 + €1739 = €2096
- Babyface Pro FS (USB) and ADI-2 Pro FS R BE = €698 + €1739 = €2437
- RayDAT (PCIe) and ADI-2 Pro FS R BE = €585 + €1739 = €2324
FD10 wrote:I would like to have the device with the best AD/DA conversion and headphone amplifier that is closest to the ADI-2 PRO.
You said you need a device that comes closest to the ADI-2 Pro, but you didn't mention the ADI-2 DAC.
I understood you that you preferred to use an ADI-2 FS for simplicity, but I can assure you that ADI-2 DAC and Pro are really great devices and there are only a few things to configure. When the setup is done, you only have to turn one volume knob, but you can enjoy all the great features that only these devices can offer you.
slow ramp-up of volume when plugging phones (DAC/Pro) or switching between channels (Pro)
dynamic loudness which is very useful when listening to background music, even during home office work
Auto Reflevel selection to automatically get the optimum Reference Level and highest SNR by simply turning the volume knob, works excellent in combination with dynamic loudness, etc
Makes quick Bass/Treble adjustments possible by using B/T knob as music material from 60's, 70's, 80's etc can be quite different ...
To get a quick idea what the differences of ADI-2 DAC/Pro are, please see this sticky:
https://forum.rme-audio.de/viewtopic.ph … 06#p165706
Only the units ADI-2 DAC FS and ADI-2 Pro FS R BE are based on the current AKM AK4493 converters
with slightly higher SNR values,
the new digital filter type SD LD (Short Delay Low Dispersion) and
allow the selection between different AD/DA filter types.
Only the ADI-2 Pro FS R BE supports four different reference levels which are optimized for studio use.
The final choice for a recording interface would depend on the connection possibilities of your computer (USB, TB, PCIe), you haven't reported anything about that yet and what else you want to do with the device.
It could even be that you would be best served with a UFX II or UFX+ alone.
That's why more information is needed about what you want to do with the equipment in order to give you the best possible advice.
This informaiton is intended to give you a 1st good overview.
If something should be unclear or if you have any question, please do not hesitate to ask.
