I had a bit of a light bulb moment, I have THX AAA 789 headphone amp there shouldn't be a reason why I wouldn't be able to max out the volume on it and use it as power amp, and use RME as pre, so I did
here are the specs of AAA789
General
All parameters measured at 0 dB gain, 1 kHz, with balanced inputs and 300-ohm load unless otherwise noted
Inputs: Stereo XLR-3 gold-plated Neutrik; Stereo RCA gold-plated
Outputs: 1/4 in (6.35 mm) TRS gold-plated Neutrik; 3.5 mm TRS gold-plated; XLR-4 balanced gold-plated
Frequency response: + 0.01 dB / - 0.03 dB 20 Hz–20 kHz; + 0.05 dB / - 0.15 dB 10 Hz–50 kHz
Input impedance: 50 kOhms balanced or unbalanced
Chassis: High-grade CNC-milled aluminum with bead-blasted finish
Power supply: 24 VDC inline brick, universal input 100–240 VAC
Dimensions: 8.3 x 9.1 x 2.2 in (210 x 230 x 57 mm)
Weight: 3.4 lbs (1,520 g)
Balanced Output
Output power: 6000 mW, 16 ohms, <1% THD (watts per channel)
Output power: 6000 mW, 32 ohms, <1% THD (watts per channel)
Output power: 800 mW, 300 ohms, <1% THD (watts per channel)
Output power: 400 mW, 600 ohms, <1% THD (watts per channel)
THD: -143 dB, 300 ohms, 1 mW: 0.000007%
THD: -140 dB, 300 ohms, 100 mW: 0.000010%
THD: -130 dB, 32 ohms, 1 mW: 0.000032%
THD: -130 dB, 32 ohms, 100 mW: 0.000032%
THD: -122 dB, 16 ohms, 1 mW: 0.000080%
THD: -122 dB, 16 ohms, 100 mW: 0.000080%
IMD: -123 dB, SMPTE 70 Hz + 70 kHz, 300 ohms: 0.000071%
IMD: -124 dB, DFD 18 kHz + 19 kHz, 300 ohms: 0.000063%
Crosstalk: -127 dB, 300 ohms: 0.000045%
Noise (A-wt): 2.4 uV, potentiometer at nil
SNR: 136 dB, 300 ohms, <1% THD
Gain: 0.66x , 2.0x, 6.6x (-4, +6, +16 dB), selectable via front switch
Output impedance: < 0.1 ohms
My most sensitive phones are Focal Elear so I used them, they are at good listening level on a bit below half volume on AAA and +1 ref, 0.0vol on RME. My room is a bit loud at 23~25db, I also created profiles on rme so I could quickly switch between pure dac and preamp modes.
on gain 1 volume had to be reduced to -32.5 on rme (auto ref on) for my listening level (~80db) and I didn't notice any difference, next I switched 789 to max gain setting of 3, the volume level went down to -52db, I still couldn't hear any noise I even tried tuning 789 off to see if there will be a difference, and there wasn't, I also didn't notice any other difference in audio quality compared to dac mode, I was really surprised that 789's input stage could handle the signal that low without completely crapping out let alone to sound like it was driven with line level.
So I guess that's what I learned today.
