Topic: Latency/sync issues between HDSP PCI and HDSP Cardbus in same machine
My DAW setup is as follows:
- i7-2600K
- Windows 10 v1909 (updated with latest patches)
- Multiface on HDSP Cardbus, connected to Ricoh Cardbus->PCI adapter
- Digiface on HDSP PCI v1.8 card (BOOT jumper is closed)
- 3x 8 channel ADAT preamps connected to Digiface
- Sync via Wordclock, using properly terminated 75 Ohm cabling
- DAWs tested: Cakewalk 2021-04 & Reaper
- RME driver version 4.38
I am experiencing erratic latency/sync issues between the cards. At first boot things normally work fine. I usually leave my DAW on, to continue on projects next day. I turn off the power to my display, RME breakout boxes etc. When I turn it on again, therere are multiple issues:
1. Routing in DAW between channels of one of the interfaces and the other (say, e.g., input ADAT 12 from Digiface, master out Multiface Analog 1/2) incurs a huge latency (like 4-500 ms or so)
2. Sometimes routing (in DAW) like in point 1 does not work at all, as long as I'm monitoring 1 channel on Multiface and 1 channel on Digiface at the same time.
The only way to make it work normally again is either:
1. Pulling out and re-plugging the HDSP Cardbus card or
2. Rebooting the PC
Does anyone have any idea what the cause of the problem can be? Could it be related to having two bus-mastering PCI devices at the same time, and some conflict?
I used to use a little different setup until recently, where none such issues existed at all:
- The same RME HDSP Cardbus in Cardbus->PCI-adapter
- RME HDSPe Expresscard in Expresscard->PCIe adapter
The reason I now am using the Cardbus + PCI combo instead, is that the HDSPe Expresscard seems to have a mechanical issue where it often loses connection to the PC, requiring many reinsertions before working again. Contact cleaning did not help, I think it's the black plastic around the Expresscard connector that's worn down a little that perhaps causes a misalignment or curvature.
