1 (edited by ekg 2021-06-30 22:07:09)
Topic: MIDI Remote Notes not working
Hi there,
I need some help, I am on this for quite a while and tried many things, but for some reasons it does not work.
I have a quite complex setup but I try to make it clear and as short as needed.
I want to control Totalmix from ableton. I use a midi loop internally on the mac.
First of all, the CC messages and fader controls are working just perfect! So the configuration is working.
BUT, the remote commands via notes do not work. I mainly want to recall snapshots.
I tried midi clips on various notes (also the octaves), I used a keyboard and a velocity filter to send out just 0 & 127 values.(https://forum.rme-audio.de/viewtopic.ph … 380#p79380)
but no luck. NO change, no reaction. Same track from ableton, sending CCs, boom. works.
I tried A5, A6, A4. played from a keyboard or from the clip.
I referred to the manual, but none of those notes work. I used channel 1
Any help appreciated!
Best, S
Dim: 5D / 93 / A 6
Mono: 2A / 42 / #F 2
Talkback: 5E / 94 / #A 6
Recall: 5F / 95 / H 6
Speaker B: 32 / 50 / D3
Cue Main Out: 3E / 62 / D 4
Cue Phones 1: 3F / 63 / #D 4
Cue Phones 2: 40 / 64 / E 4
Cue Phones 3: 41 / 65 / F 4
Cue Phones 4: 42 / 66 / #F 4
Snapshot 1: 36 / 54 / #F 3
Snapshot 2: 37 / 55 / G 3
Snapshot 3: 38 / 56 / #G 3
Snapshot 4: 39 / 57 / A 3
Snapshot 5: 3A / 58 / #A 3
Snapshot 6: 3B / 59 / B 3
Snapshot 7: 3C / 60 / C 4
Snapshot 8: 3D / 61 / #C 4
Trim Gains: 2D / 45 / A 2
Master Mute: 2C / 44 / #G 2
Master Solo: 2B / 43 / G 2
2 (edited by waedi 2021-06-30 23:11:43)
Re: MIDI Remote Notes not working
May be the note messages don't arrive the computer system ?
For checking this in a mac there is a little programm for free : Midi-Monitor.
Let this programm run and press the keys on the keyboard.
It shows every midi message passing the system.
https://www.snoize.com/midimonitor/
3
Settings, tab MIDI: These notes only work when Mackie Control support is enabled. CC always works.
Awww! Ok, easy. Now it is working of course.
Thank you!
