>>Are you using "Locked Volume"?
Yes, but only at Line Out, +13 dBu and Volume to -4.5 dBr LOCKED, Auto Pref ON
>>It seemed an earlier post of yours suggested you were. If this were the case, then your Dynamic Loudness function is disabled, and no longer part of the equation. Should it be that you are NOT using Locked Volume, then it needs to be remembered that Dynamic Loudness boosts are not fixed. Boosts are MAX at your chosen Low Vol. Ref, and decrease over a 20db range as Volume is increased.
I forgot to mention, the questions are for IEM and phones.
>>As to "Who" takes priority? Well...consider that your Enormous B/T boosts (set on Encoders 1 and 2) stay regardless. Dynamic Loudness boosts on the other hand, take care of themselves, and again, go away as Vol. listening level is increased.
So the Loudless boosts kick in at the preset -"x"db value, right? And is it constant? You mentioned dynamic, means the lower the volume turn down, the boost gets more?
>>Let's be sure we're not interchanging B/T settings with Dynamic Loudness settings.
Make any sense?
Is that mean the Loudness boost will add on top of the B/T values?
I am ADAT user before, since when I became expert? I AM NOT !!
Pacifist, dumb, not stupid
