Topic: Audio Conections AES
Hello from New Zealand smile
For love or money (manual study, forum reading, you tube digesting) I cannot find AES or SPDIF in my DAW audio connections. I would really like to bounce down the stereo mix to a stereo channel.
I have XLR's from digital out and in from desk to card and I am getting sound from 2TR-D1 to monitors, I just cant route it back into my DAW.
Yamaha o2r-RME-Raydat-Cubase 11 Pro.
Any help appreciated.
2 (edited by waedi 2021-08-22 03:37:39)
Re: Audio Conections AES
Ahoy hoy ! Channel numbers 33/34 in Cubase VST connections should be the AES of the RayDat, The SPDIF should be 35/36.
M1-Monterey, Madiface Pro, Digiface USB, Babyface silver
Thanks for the reply. I am only seeing 32 channels
4 (edited by waedi 2021-08-22 06:09:11)
Then check the channel layout dialog for hidden channels.
May be the AES and SPDIF has become "hidden" ?
In Totalmix rightclick on an output channel to find the Layout dialog window.
User manual 20.5.3 is also helpful for this.
No, not hidden. I will have a look at the manual again.
6 (edited by waedi 2021-08-22 06:46:58)
How looks Totalmix ? Are the AES and the SPDIF missing there too ?
For Windows users, there is a WDM devices configuration dialog in the settings, may be you have to enable AES and SPDIF there ?
7 (edited by piratenaki 2021-08-22 08:52:47)
Totalmix has the channels not hidden.
WDM devices have AES and SPDIF showing. I am using AES to play Spotify etc. I can even sent monitor mix from desk, just nothing showing in Cubase. I think I can eliminate the issue being in Totalmix.
8
In Cubase I/O settings there is a reset button. Try this, then the channel list should be complete. Thereafter you have to assign the channels with busses, this might fail when done automatically.
I have reset a few times (every time I try something new).
I'm at a loss. Wondering if I should reinstall software.
Hello!
Did you try with another DAW? Reaper, for example?
12
Also shows us a screenshot where you do the reset and how that list looks like. Are you sure your Cubase version is able to handle more than 32 channels?
https://i.ibb.co/x2b5nmn/Reset.jpg
https://i.ibb.co/FJDdcJq/Totalmix.jpg
Cubase Pro 11 has 256 channels input and output
Cubase Artist 11 has only 32 channels input and output
Maybe Cubase Artist 11 is installed by mistake ?
No AES or SPDFF in Reaper either.
16
Open Settings dialog, Tab Global. Is the ASIO32 Channel option active? Toggle it to make sure it is off.
If that's not the cause: Which driver version is used? Which firmware version is in the card now?
Fixed!!!!
Thanks so much for you time and patients!
