1 (edited by Bluzzi 2021-09-30 17:45:39)
Topic: Problems with HDSP 9652 install SOLVED!
Just installed an HDSP 9652 (I bought used) on Windows 7 64bit. I installed driver 4.36 and driver shows up but not the channels. The cards are installed properly as far as I can tell because the ADAT out ligh up (it's minimal indication that card is OK).
The seller told me to run the flash update tool and I ran the fut_wdm_dsp.zip but it does not even run! I've ran the driver several times and restarted as many at least.
Previously I had the DIGI9652 running on Win 7 32 bit flawlessly.
Any tips to know what's happening would be really appreciated.
Cheers
Jim
Re: Problems with HDSP 9652 install SOLVED!
The card is not recognized in your system. What PCB revision is printed on the card? There have been old versions that require a hardware modification to run on newer systems.
If it is a digi9652 it will not run on 64 bit. If a hdsp9652 it will.
OK I solved the problem for now (I say that because it i snot hooked up to my ADAT AD/DA converters yet). I uninstalled the 4.63 drivers and installed the 4.29 drivers and it works now.
Appreciate the quick help I got here.
Cheers
Jim
