Topic: Problems with HDSP 9652 install SOLVED!
Just installed an HDSP 9652 (I bought used) on Windows 7 64bit. I installed driver 4.36 and driver shows up but not the channels. The cards are installed properly as far as I can tell because the ADAT out ligh up (it's minimal indication that card is OK).
The seller told me to run the flash update tool and I ran the fut_wdm_dsp.zip but it does not even run! I've ran the driver several times and restarted as many at least.
Previously I had the DIGI9652 running on Win 7 32 bit flawlessly.
Any tips to know what's happening would be really appreciated.
Cheers
Jim
