andrew wrote:I’m attempting to get a h/w input out to a software package running on the computer hosting TotalMix so that I can convolve the signal.
You are not speaking of two computers, one with the interface and Totalmix and a second computer with that convolution software ?
If all is in one computer then it is very easy.
No routing needed for the hardware input signal.
As you can see the signal in Totalmix hardware input, the signal is already available for your software.
The software must have an options menu where you have to select the input channel.
Only the output of the software has to be routed to the speakers.
In Totalmix you should see the signal from the software in the middle row (software playback channels).
Route it to the speakers.
