Topic: Option to exclude Volume from Setup
Hello, I am using Setup store and load function to change functions not available with Remote - Width and MS processing while mixing. So I need to listen to my prod as stereo and then as mid-side with the same volume. But if I change the volume in current setup the next setup I use will be loaded up with the stored volume. Could you please add an option to exclude the volume parameter from storing/loading with setup?
