Topic: Pre-FX spectrum setting
Would it be possible to add a setting to make the spectrum display work with the pre-FX audio, similar to the setting for the horizontal volume meter? I know changes in the spectrum are not quite as extreme visually as for the volume meter, but a reasonable EQ correction for a headphone like the HD800 can easily hit +10 dB in bass and -5 dB in treble. That makes the spectrum look a lot bassier than it actually sounds.
