Topic: Babyface Pro FS Headphone Output (6,35mm) Crackling Noise
recently i noticed a unmistakable crackling on the 6,35mm headphone output of my babyface Pro FS.
The crackling seems to be relative to the amount of data transmitted trough the lan network apdater on my desktop...
The crackling dont happen on the smaller 3,5mm headphone output.
Maybe a hardware fault with the babyface or any ideas?
Thanks for help smile
Manuel
Re: Babyface Pro FS Headphone Output (6,35mm) Crackling Noise
Sure the headphone adapter is not faulty ?
Is it a screwing one ?
3 (edited by Manu 2022-01-08 18:17:07)
Thanks for the suggestion smile
But i already tried different headphones, adapters and so on. Always same behaviour...
Manuel
4 (edited by Manu 2022-01-10 23:26:48)
Some other ideas? In case of doubt i better should return the device sad
Manuel
Before sending the unit back I would try to sort out this network adapter.
Try the unit on a different computer.
6 (edited by Manu 2022-01-11 00:03:00)
I have different other usb-interfaces (also cheaper) without this problem. It seems that there is some interference current leaking to the headphone-out.
But only to the 6,35mm jack. I dont know if i can take this drawback with an interface in this pricerange. sad
On a different computer theres no problem but should i blame my network adapter for this? Other interfaces working without problems.
Manuel
This points to a defective output, in this case I would send the unit in for an inspection.
Thats very sad to hear but i have expected that sad
Manuel
