Topic: Help Babyface please!
Hello!
I'm trying to properly setup a silver and blue babyface and have hit my head on the desk for quite some hours. The first issue was that once setup there was no audio in the headphones, either one of them. After lot of trial and error, and referencing manual finally I found out about "TotalMix Fx" which for some reason was nowhere on the CD that came with the Babyfaces.
Strangely, TotalMixFX was also nowhere to be found to download even when going to the support website and selecting the Babyface product, all that was shown was the 1068 driver update, the firmware update download, and Digicheck download.
Finally after doing some heavy googling, I found a link in a forum here to a zip file with TotalMixfix and after running that, like by magic suddenly we had Audio in the Headphones on playback etc.
The next problem adding a couple more bumps on the head was getting Live Audio Monitoring to work. I was using Audacity, tried many different things, 'software playback' in edit preferences, tried using computer built-in soundcard/interface for the audio monitoring but too much delay/latency so obviously I needed to get it to work through headphone jack direct on babyface.
Well I finally found out that if I enabled REVERB or ECHO inside TotalMix FX, all the sudden I have Live Audio Monitoring in terms that I can hear in the headphones whatever I'm saying through the microphone in basically more or less realtime it seemed.
So here's my problem now, I don't see how I can DISABLE the "through" audio so I don't hear myself in the headphones but to still have REVERB and AUDIO enabled so that I can RECORD the TotalMix FX "wet" signal.
(ALSO though, how do I do LIVE Audio Monitoring without Reverb or FX enabled? Right now I can only hear myself in the headphones if I have Reverb or Echo enabled in Totalmix, I have not figured out how to monitor myself Dry without reverb or echo with just TotalMix. I was able to do this with Kristal Audio Engine with it's "monitor" feature on the track and Echo/Reverb disabled on the TotalMix, that way I can hear my dry voice in headphones for live "dry" monitoring, but this doesn't work with Audacity since it seems Audacity doesn't support ASIO so I was hoping I could just have TotalMixFx do it, and it works but only if I enable Reverb or Echo and I'd like to also be able to hear it dry since Audacity can't record TotalMix Reverb anyway, or can it?)
So how should I record the TotalMix FX's Reverb or Echo so that my recorded WAVE file has a wet signal in it with the fx? I was able to do that only with KRISTAL AUDIO ENGINE not with AUDACITY, but I did it by enabling "loopback" in the TotalMixFX hardware output for Analog 1/2 of babyface.
The problem with this though is that when I try to record a Second Track inside Kristal Audio Engine (using ASIO) I get bleeding of the 1st track playing back into my second track recorded. This doesn't happen if I disable the "loopback" in hardware output it seems but then I miss out on recording the wet totalmix's reverb signal to file. Any solutions?
