Topic: RME ADI-2 DAC FS -> PURIFI Amps
I'm a happy new owner and really like the device. I've read a lot of stuff in this forum. My "chain" :
PC/Android Phone ->USB-> RME ADI-2 DAC FS -> XLR -> Audiophonics Purifi Monoblocks-> KEF R3
Sounds absolutely awesome ! I'm really Impressed.
My question : The input buffer boards on the purifi amps' gain settings can be changed. From audiophonics website:
Gain of + 7.2dB, for a total of 20dB (default) - Maximum power reached with a signal of ~ 4.2V RMS
Gain of + 12.5dB, for a total of 25.3dB - Maximum power reached with a signal of ~ 2.2V RMS
Bypass: in this case the signal passes directly from the inputs to the modules, allowing the lowest possible gain of 12.8dB. This mode can be interesting when using a powerful preamplifier, capable of driving a load of 2 to 4kOhm and reaching a voltage of ~ 10V RMS
I Listen at -30 to Max-20 (very silent recordings) all the time. Auto Ref on the RME is on. Would it be beneficial to use the bypass Option on the amps?
Thank you very much in advance !
Greets
